Highlighted
by Investigator
Broadband not accepting my password
My BroadBand switched off last night, and when it came on again and I tried to reconnect, it would not accept my password. I cannot even see how to reset so I can activate it again...HELP!
Highlighted
by Investigator
Cannot log back into broadband, as my password is not recognised. Can you help?
Highlighted
by Ace Contributor
Re: Cannot log back into broadband, as my password is not recognised. Can you he
Hi @Basmaniac
Welcome to the Community,
What are you unable to do log into MyEE or are you having issues with your broadband password ?
Unfortunately there is no account access here on the community if you give 150 a call from your EE mobile or 0800 956 6000 from a landline from 8AM in the morning & a advisor be able to help.
Highlighted
What do you mean? Your router doesn't log into the BB network or you cannot log into your MyEE for BB a/c? Please be a bit more explicit & say what you are trying to do.
Highlighted
Re: Broadband not accepting my password
@Basmaniac: What is the form of your BB Username? If it is like "PRODUCTIONHQNUN123456@fs" the pwd is like "HQNPASS123456". Simply replace the numbers in the password, with the ones found in your username.
