by Dralex76 Investigator
Broadband issue poor download speed
Lately I had a lot of issues with my broadband. First during a week I had lots of disconnections where the internet light of the box was flashing orange then back to green then orange again etc ...
This hasn't happen lately but now I have lots of very small disconnections like this:
Request timed out.
Reply from 209.85.203.94: bytes=32 time=36ms TTL=46
Reply from 209.85.203.94: bytes=32 time=37ms TTL=46
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 209.85.203.94: bytes=32 time=35ms TTL=46
Request timed out.
Reply from 209.85.203.94: bytes=32 time=38ms TTL=46
Request timed out.
Request timed out.
Request timed out.
Reply from 209.85.203.94: bytes=32 time=55ms TTL=46
And my download speed is very poor I used to dl at 2.0Mb/s now I hardly reach 700Kb/s ...
Here is the info requested by the main post:
My speedtest:http://www.thinkbroadband.com/speedtest/results.html?id=1487275937652778455
My Exchange code is : LVCEN
And my DSL status:
INTERNET Broadband Type ADSL Broadband State Connected Internet State Connected Time Connected 00:31:57 Downstream Rate 6.65 Mbps Upstream Rate 0.44 Mbps IP Address 95.145.
Hope someone can help me I am starting to go crazy xD
Alex
Solution
Re: Broadband issue poor download speed
You have indeed had 35 discons since you last rebooted, but it's not those busy servers. There also could be a lotta errors depending on how long it's been up. Please post 'System Uptime' from top of System Log page.
Have you tried running at the test socket? Have you done the QLT?
You should be syncing at about 20 Meg instead of the 6652 K that you are. The reason you are not is that the DLM system has put you on a banded profile in response to past errors on your line, the 7th lowest of these Banded Profiles. You need to call EE to reset the DLM in order to remove any banding. However should significant errors persist the DLM will reapply banding.
URGENT: Plse remove everything from "xx.yy Broadband Username" by editing. You are giving away your passwords & other hackable stuff to the wide world.
Request timed out.
Request timed out.
Those are not discons but just servers that don't or are too busy to respond to pings. They still pass your stuff on. This is common. So, lately you are not getting discons.
Sorry, thar's not the right page. Please navigate exactly Advanced Settings/ Accept/System/ DSL Status.
Thank you very much I indeed copied the wrong page 😮
THere you go:
STATUS   Configured Current Line Status -- UP Link Type -- Interleaved Path Operation Mode Automatic G.992.5 (ADSL2+)
DATA RATE INFORMATION Upstream 444 (Kbps) Downstream 6652 (Kbps)
DEFECT/FAILURE INDICATION Operation Data Upstream Downstream Noise Margin 25.4 (dB) 16.4 (dB) Line Attenuation 7.7 (dB) 19.5 (dB)
Indicator Name Near End Indicator Far End Indicator Output Power 12.8 (dBm) 0.0 (dBm) Fast Path FEC Correction -- -- Interleaved Path FEC Correction 14395164 0 Fast Path CRC Error -- -- Interleaved Path CRC Error 0 12834004 Loss Of Signal Defect 35 0 Fast Path HEC Error STR -- -- Interleaved Path HEC Error 1 297979 Error Seconds 834 2
STATISTICS Received Data 440820 (Kbits) Transmitted Data
128726 (Kbits)
If they are not discons though why don't I have access to the internet during those .?
Alex
Solution
Ok thank you I will then call ee tomorrow.
For the rest I tried to run it at the test socket but no difference. And I don't own a pghone so can't do the QLT 😞
