by georgeboul
Broadband home bill "extra charges: normal workday fulfilment"
Hello everybody,
Any idea what is the bill item "extra charges: Time charge normal workday fulfilment 51.95" in my monthly home bill (broadband and calls). Thank you.
by Profile closed
Not applicable
Re: Broadband home bill "extra charges: normal workday fulfilment"
I believe that is either an installation charge if you are a new customer or a BT OpenReach engineer visit charge if you have recently had a fault with your broadband where an engineer had to visit your property and the fault was found to be on your side of the master phone socket.
