by smoothster
Broadband drops every afternoon - outages getting earlier and longer tho variabl
Broadband drops every afternoon - outages generally getting earlier and longer though variable. EE technical support sent a new router but problem continues. BT linecheck says no fault. Any ideas? There have been no changes to set up in the rest of the house.
Have tried connecting router directly to phone socket (with EE provided new filter) but no better - just inconvenient because router now in next room.
Re: Broadband drops every afternoon - outages getting earlier and longer tho var
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
by smoothster
Broadband connection now restored so here are the data you asked for:
1.
DSL STATUS
This page shows information about your DSL connection. If you are using Fibre/Ethernet Broadband then this page is not applicable.
STATUS
Configured
Current
Line Status
UP
Link Type
Interleaved Path
Operation Mode
Automatic
G.992.3 (ADSL2)
DATA RATE INFORMATION
Upstream
856 (Kbps)
Downstream
3052 (Kbps)
DEFECT/FAILURE INDICATION
Operation Data
Upstream
Downstream
Noise Margin
8.0 (dB)
8.8 (dB)
Line Attenuation
26.3 (dB)
45.0 (dB)
Indicator Name
Near End Indicator
Far End Indicator
Output Power
12.6 (dBm)
0.0 (dBm)
Fast Path Fec Correction
Interleaved Path Fec Correction
115
0
Fast Path Crc Error
Interleaved Path Crc Error
0
0
Loss Of Signal Defect
98
0
Fast Path Hec Error Str
Interleaved Path Hec Error
0
0
Error Seconds
1604
957
STATISTICS
Received Data
53367 (Kbits)
Transmitted Data
8244 (Kbits)
System Uptime is: 26:13:09
2. Wired speed test not possible as I moved router so that it was connected directly to the phone socket and not via an extension. The ethernet cable is not long enough.
The results of the speed test by wireless connection are here:
https://www.thinkbroadband.com/speedtest/1558111283525748055
3. My exchange is St Andrews, Fife
https://availability.samknows.com/broadband/exchange/ESSTA
It's running v. slow, had 98 discons in 26 hrs & should be in ADSL2+ mode 😞 . There's something afoot with that line.
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
