by stebli Investigator
Broadband drops everday - tried everything
So after upgrading to Super Fast broadband and receiving a new Smart Hub, the very next day problems started.
So I reported in May that my broadband was dropping almost every day at a similar time of day 8pm - 10pm (usually but not always)!
After going through the usual pointless steps I eventually got an engineer out to look at the line etc. He did several things including changing the 'box' on the wall as it was an old one.
This made no difference.
The engineer came back and changed all of the external cables from the telegraph pole.
I gave up and just accepted it, but it's just the same and has been for months and now i can't take it any more.
The only thing i can think is that this is either a firmware issue or a hardware issue - can anyone help?
Re: Broadband drops everday - tried everything
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Product name:Smart Hub
Serial number:+EEH001+1850002461
Firmware version:v0.00.24.06190-EE
Firmware updated:Your Firmware has not been updated.
Board version:01
DSL uptime:0 Days, 1 Hours, 8 Mins, 21 Secs
Data rate:20.00 Mbps / 80.00 Mbps
Maximum data rate:20.12 Mbps / 94.80 Mbps
Noise margin (up/down):6.1 / 10.4
Line attenuation (up/down):24.6 / 17.8
Signal attenuation (up/down):24.5 / 17.8
Data sent / received:58.3 MB / 359.8 MB
Broadband username:bliwert.orangehome.co.uk@fs
2.4 GHz wireless network name:EE-Hub-tMD3
2.4 GHz wireless channel:Smart (Channel 6)
5 GHz wireless network name:5GHz-EE-Hub-tMD3
5 GHz wireless channel:Smart (Channel 48)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:44:FE:3B:C4:D1:3A
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017)
Don't have any issues wired or wireless when it's working, just the 5 minutes everyday that it drops and reconnects.
