by novacomet Investigator
Broadband dropping out
Hi. My fibre broadband keeps dropping out every 2-3 minuites. I have tried to contact EE with the 020 number as im calling off a o2 mobile and the number isnt working. I have tried it a few times and it doesnt connect. HELP as i need to get intouch with them as i only have netflix to watch and im unable to.
Re: Broadband dropping out
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
hi im not with the router as i have had to come to my parents to get online to look for help.
Hi @novacomet,
You can contact Customer Care on 0207 362 0200 from your O2 mobile or 0800 079 8586 from your EE landline.
