by Krammer11
Broadband disconnects when PS4 goes online
Hi all
Got this current issue. Broadband works intermittently, but disconnects when I go online with my PS4.
Also the house phone doesn’t work when I plug both the house phone and broadband cable into the micro filter - splitter.
Any advice greatly appreciated.
Re: Broadband disconnects when PS4 goes online
Are you sure that it's the BB that discons or could it just be the WiFi? How is the PS4 connected?
Does the phone socket have 1 or 2 outlets. Please post an image of it.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
