Highlighted
New Member
Broadband Dropouts
I keep having daily dropouts, it seems to be I. The evening on my broadband they let for around 5 minutes each time and are consistent daily. Other than that my speed and connection is fine, anyone experienced this?
- I have reset router
- I have checked area status for maintenece
Highlighted
by Established Contributor
Re: Broadband Dropouts
Hi - Could you tell us what broadband plan you're on, and which router you have?
I have had a similar issue lately with my Smart Hub on Fibre Max 2 - the internet would drop out, and the hub management page failed to load. We didn't have this issue before upgrading, and I nailed it down to an issue with the Smart Hub and the usage of the 4th ethernet port as a WAN port.
Unfortunately, I found no solution to this other than purchasing a third party router - which I have done. Since it's a common issue with the SH, replacement units won't help, and EE doesn't currently have a suitable alternative to my knowledge - without downgrading your connection quality.
Highlighted
If you mean EE's Network Status Checker, that's only for the EE mobile network & does not apply to the EE BB network.
Highlighted
@Daz23634@Silgica  : Welcome to EE's Home Broadband Forum.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & numbers in the BB Username & also the SSIDs.
3. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Recent solutions
