Highlighted
by Investigator
Broadband Connection Drop Outs
Hi, my home broadband is suffering from an unacceptable number of drop outs. Basically, when it is connected, the speed is fine. However, the frequent drop outs are starting to make it unusable for streaming etc. I’ve done the silent line check and it is ok and there are no internal extensions connected in the master socket.  This problem is happening with all devices, not just one.
Does anyone have any ideas on what the issue could be?
Highlighted
by Investigator
Solution
Re: Broadband Connection Drop Outs
A quick update.
Thanks for your help so far, but I've solved the problem.  The issue was overcrowding.  When I checked my network, I saw that all of the consideable number of devices in my home were using the 2.4GHz band.  I seperated the wifi bands on my router and allocated devices between the 2 bands and hey presto! the number of drop outs has reduced dramatically.
8 REPLIES 8
Highlighted
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & numbers in the BB Username & also the SSIDs.
3. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Highlighted
by Investigator
Product name:Smart Hub
Serial number:+EEH001+1913003992
Firmware version:v0.04.02.09120-EE
Firmware updated:Wed Nov 27 09:32:17 2019
Board version:01
DSL uptime:0 Days, 12 Hours, 55 Mins, 1 Secs
Data rate:13.05 Mbps / 67.97 Mbps
Maximum data rate:13.05 Mbps / 67.45 Mbps
Noise margin (up/down):6.1 / 3.4
Line attenuation (up/down):24.9 / 19.9
Signal attenuation (up/down):24.7 / 19.9
Data sent / received:924.3 MB / 3.2 GB
Broadband username:PRODUCTIONHQNUN436665959@fs
2.4 GHz wireless network name:EE-Hub-4wZp
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:EE-Hub-4wZp
5 GHz wireless channel:Smart (Channel 44)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:64:CC:22:6C:8D:2D
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017)
Highlighted
by Investigator
Telephone Number xxxxxxxxxxx on Exchange METHERINGHAM is served by Cabinet 8
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
735018.111.744.6AvailableAvailable--
70.344.417.61035AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 17--15 to 18.5AvailableAvailable--
Up to 17Up to 1.515 to 18.5AvailableAvailable--
Up to 8--7 to 8AvailableAvailable--
2----AvailableAvailable--
2----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
66.03
13.42
2020-05-02
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
U
N
N
12-05-2020
Highlighted
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
Highlighted
by Investigator
Hi, I’ve redone the quiet line test and it’s still ok. I don’t have any extensions connected to the internal last of the master socket. I’ve not been able to plug the router directly into the test socket as I got rid of my filters/adapters when Open Reach installed my MK3 socket (some time ago). Is the purpose of plugging the router directly into the test socket to check that the filter in the master socket hasn’t failed?
Highlighted
No, it's just to see if the router stats have changed.
Can you tell whether the drop-outs are of the BB as a whole or just the WiFi dropping?
Highlighted
by Investigator
Devices are still showing as connected to the Wi-fi when it happens, so I would say it’s the BB as a whole.  It was a bit of an issue when I first switched from BT (last year) and I did the QLT which was ok and then removed all of the extensions (which were unused anyway) and that made it better. However for the last week it’s been awful. Nothing has changed in terms of devices connected to it and nothing has been moved around.
Highlighted
by Investigator
Solution
A quick update.
Recent solutions
