Brightbox2 as wifi repeater
Posted in the open:
@kirkofski wrote:
Hi There,
I'm trying to setup a spare second brightbox 2 router as a wifi repeater as the wifi is poor on one side of the house.
I've got an ethernet cable plugged into the first Brightbox 2(1 of 4 yellow ports) and then the other end is plugged into the Red WAN port of the second Brightbox 2 router.
I've logged into the second Brightbox 2 router and changed the Radio setting to "Ethernet" and protocol to "Routing".
After that I'm confused about these subnet, DCHP bits(I'm a totally newbie to settings like that).
Do I need to call both routers the same name and have the same password? Is it the case that if I do that then wifi devices will switch seemlessly from one router to the other as we move around the house?
Many Thanks
Rob
Solution
Re: Brightbox2 as wifi repeater
@kirkofski: If you search this forum you will find many discussions on using a 2nd router to extend the wireless of your main 1, such as To make the BrightBox 1 a WAP on your LAN , where your 2nd BB2 will stand in for the BB1 of that article.
Solution
by Chaoss Investigator
Just a thought, I found this thread from Googling you might want to include those links in your post as Forum searching is disabled if you're not registered.
@Chaoss: What links in my post?
@Chaoss: You don't need to be registered to this Community to be able to search this Community.
