by tcdaly Investigator
Brightbox 2 bridging mode
Regarding the Brightbox 2: on the 'Advanced -> Broadband settings' page, when 'Broadband type' is set to 'Ethernet' and 'Protocol' is set to 'Bridging', what exactly does this mode do, and what would it be used for?
Solution
Re: Brightbox 2 bridging mode
Yes, of course, they are for connecting the devices that this router is bridging to the main router. The WAN port is connected to the main router.
It passes any connections to it on to another router at the other end of the Eithernet which will do all the routing.
It can be used to turn the router inro a wireless extender to the main router as in To make a second Brightbox as a WAP on your LAN to the main Brightbox .
The Protocol may also be set to "Routing" allowing both routers to each do their own routing but that gets a bit more complicated.
Thank you.  Does this mean that in 'bridging' mode, the WAN and PPPoE section of the router is completely disabled?
The PPPoE option, yes. & also the DSL modem. I dunno what you mean by "WAN section". The Ethernet cable is plugged into its WAN port, so it can't be disabled.
That's what I meant, the DSL modem/PPPoE section.  If the WAN socket is used to connect to an ethernet network, is there any role for the LAN sockets in this configuration?
Solution
