by Iyad Investigator
Brightbox 2 Internet flashing orange
The brightbox 2 internet is flashing orange and it's disconnected from the internet. It's been like this for a day. I'm really confused as to why this has happened.
I took a pic of what it looks like: http://imgur.com/a/OdYCY
Solution
Re: Brightbox 2 Internet flashing orange
Check your BB Username & password in the router are correct.
Are there "PPP: CHAP authentication failed" in the log?
How long have you had this BB with EE?
You can try a factory reset, remembering it will undo any of your own settings you have set.
7 REPLIES 7
Hi @lyad,
Welcome to the EE Community.
Have you tried restarting your router?
Solution
Yeah the user/pass are correct, had BB2 for a very long time now. Since release.
Also where are the logs on the admin panel.
Yes, I've done this around 5 times throughout the day. Nothing..
Factory reset worked!!! Thx 😉
You're welcome :)! Glad I could be of assistance.
EE Employee
Glad you're now sorted @lyad
Many thanks,
Lee
