by DDC1 Investigator
Bright box repeater
Any ideas as how I can use old type bright box as a secondary wifi extender wireless, using bright box 2 as a primary router.
A step by step guide would be great. Currently I do not have a laptop or Pc so will only able to connect to routers via iPhone 📱.
Thanks in advance.
Re: Bright box repeater
@DDC1  Have a read of THIS as it will help explain how too if it’s possible with the old router and I assume you know how to login to the admin side of the router?
EE Employee
Hi @DDC1 and welcome to the community.
Let us know how you get on with @Chris_B's help.
Many thanks,
Lee
Hi thanks @Chris_B for the link, I'll give it a go. Your assumption is correct I know how to login into admin on the router.
@DDC1: Please have a read of To make a second Brightbox as a WAP on your LAN to the main Brightbox .
