by Spurs62
Bright Box router only allowing us to connect to 5Ghz band
Please help, this is driving us mad! (Please excuse my lingo as i'm not very techy..)  We have a Bright Box router which worked fine for a while, when selecting wifi on our devices we had a choice between 2 bands (2.4 GHz and 5GHz) however now the 2.4 option has completely disappeared. We have restarted the router and tried several other tricks suggested by friends in IT but nothing is working. We have many devices in our home (laptop, older iPad, printer) that don't support 5 band so we are unable to use them. Any suggestions? Is this down to the router being faulty? Thanks in advance.
Solution
Re: Bright Box router only allowing us to connect to 5Ghz band
You mean the 2.4 GHz band SSID does not show up in the WiFi networks lists of your devices? Router must have developed a fault.
6 REPLIES 6
Solution
by Spurs62
Yep - that's precisely what I mean! Ok great, will try and get around customer services for a replacement..
Hi @Spurs62
Please let us know how you get on 🙂
Also I'm gathering your a Tottenham fan?
Good luck for the rest of the season and the huge North London Derby today.
Cheers
Richard
by Inuit
I'm having this exact same problem. Did the replacement fix the issue?
Shaun
Hi @Inuit,
Welcome back to the community.
Please get in touch with customer services. Our technical team will run through some diagnostics with you and get a replacement router straight out to you if necessary.
by Star Contributor
Star Contributor
@inuit
It might be worth having a quick look at the Router config.  go to http://192.168.1.1/ in your browser and look at the Wireless settings.  The two bands should be obvious and it maybe the 2.4GHz channel has been switched off, or the SSID is set to hidden.  I would also suggest you look to check the channel selection  1 to 11.  Best set this to auto.  It could be you have co-channel interference from a neighbour and that is upsetting the detection of the 2.4GHz band.  Setting to auto will avoid neighbours interference.
