by Bee7
Bright Box issues - wired connection works but wifi slow and drops out
I recently switched to EE and the Bright Box is driving me to madness. The internet works when wired but when I try to use it wirelessly, it's unuseable. The connection is incredibly slow to the point that it drops out. I can't load pages, I can't download anything, I basically can't do anything at all with wireless. Plug the ethernet cable back in and it's fine. Problem is, I can't plug my phone or tablet into the router.
I found a page earlier about changing the bandwidth but this did nothing.
I have tried to phone EE help but it's always so busy. I was determined to speak with someone this evening but after 22 minutes, I gave up.
Does anyone have any idea how to fix the wifi? At this rate I'm going to have to take a day off work just so I can stay on hold to speak to someone.
Thanks in advance
6 REPLIES 6
Re: Bright Box issues - wired connection works but wifi slow and drops out
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
2. Try both a wired & a wireless speedtest here http://www.thinkbroadband.com/speedtest.html and copy to here just the "Link to this result:" link.
by Bee7
DSL Status This page shows information about your DSL connection. If you are using Fibre/Ethernet Broadband then this page is not applicable.
Status   Configured Current Line Status -- UP Link Type -- Interleaved Path Operation Mode Automatic G.992.1 (G.DMT)
Data Rate Information Upstream 448 (Kbps) Downstream 1568 (Kbps)
Defect/Failure Indication Operation Data Upstream Downstream Noise Margin 17.0 (dB) 9.6 (dB) Line Attenuation 31.5 (dB) 63.5 (dB)
Indicator Name Near End Indicator Far End Indicator Output Power 12.3 (dBm) 16.7 (dBm) Fast Path FEC Correction -- -- Interleaved Path FEC Correction 708 0 Fast Path CRC Error -- -- Interleaved Path CRC Error 0 9 Loss of Signal Defect 0 0 Fast Path HEC Error STR -- -- Interleaved Path HEC Error 0 13 Error Seconds 224 0
Statistics Received Data 471544 (Kbits) Transmitted Data 50380 (Kbits)
by Bee7
This is the link for wired connection.
https://www.thinkbroadband.com/speedtest/1500668476336084155
by Bee7
When it's wireless it's dropping out. It won't work well enough to even run the test.
by Bee7
I've tried but it just won't work
Welcome to the new version of the thinkbroadband speed test.
We encountered a problem
Error Code: 4136 (Unexpected upload behaviour)
Check you have an Internet connection and try again
This error occurs when we see no data or there are anomalies.
Check your connection is not busy doing something else.
EE Employee
Morning @Bee7
Please give broadband customer services a call.
The tech teams will be able to investigate this for you.
Thanks - Karen. Smiley Happy
