by Joeh1 Investigator
Bright Box 1
Intelligent sensor.  Where is it and how do you use it?
Solution
Re: Bright Box 1
No problem @Joeh1
Intelligent wireless will automatically look for and use the best WiFi channel it can find when you first turn it on.
You can also press the intelligent WiFi button (see picture below) briefly and your router will check if it's using the best WiFi channel and swap if it isn't.
Find out more about intelligent WiFi >
Hope this helps. Smiley Happy
Re: Bright Box 1
Hi @Joeh1,
Welcome to the EE Community.
Do you mean intelligent wireless?
Re: Bright Box 1
Yes, my apologies James_B.    Can you assist?
Solution
Re: Bright Box 1
No problem @Joeh1
Re: Bright Box 1
Thank you so much for that information James, so helpful.
Joe
Re: Bright Box 1
