by t8769 Established Contributor
Block websites
I called EE Tech Support 3 times, they said you could't block website, but you can.
Its easy
Just go to http://ee.co.uk/help/phones-and-device/home-broadband/bright-box-2-wireless-router/bright-box-2-adva...  and search for URL blocking
General filter is found here
https://connectsafe.norton.com/configureRouter.html
Re: Block websites
@t8769  You can but EE can not do this for you.
Re: Block websites
Yes, obviously.
There is no way to block websites using the hub settings.
You can fill in the website addresses to block, but it will not work correctly.
However there is a far better way to block sites and have good child controls, this is OpenDNS.
It is quick, free and is far superiour.
And it works.
Re: Block websites
Yes, that'll be OpenDNS FamilyShield Router Configuration Instructions
•208.67.222.123
•208.67.220.123
