Highlighted
Bb2 time issue
My friends BB2 time settings keep going back to 00.00 jan 01. Ive read through similar topics on here but i cant see any solutions its NOT tbe time sever because it works for hours after a factory reset and immediately after it goes I factory reset and it works again... I have noticed that a DoS attack is detected hours/mins before it apparently restarts firmware with no time sync? I would appreciate some honest answers from Ee and the link for the pre-updated firmware. Thanks
Highlighted
Re: Bb2 time issue
@Mikey13   You’ll not get a link to any pre updated software as EE don’t post these are they are pushed to the router via the network.    You could try searching the web put you’ll probably find it will auto update again.
if you require to speak with EE you’ll need to call customer services, but your friend will have to call and then request that you can speak on there behalf.
Highlighted
Re: Bb2 time issue
Yes, you've led me to discover my BB2's time went back to 1st Jan 9 days ago. I won't factory reset cuz I've many of my own settings on it.
Was the DoS attack from 1 of your own devices on your LAN. It sometimes does that.
Highlighted
Re: Bb2 time issue
Hi, the address of the attacker is random and not an ip of any device on my router.
You can back up your settings. I've found i can get three days if im lucky by resetting,  changing password, then restoring (change password to your new one after restore).
I have time schedules which are pointless atm.
My theory is that the bug maybe linked to the blocking of all tcp/upd ports maybe it applies it universally hence no server.. I don't know but im  going to test.
I do have a new router from EE to try but it doest seem to have the MAC address control of the BB2? So im reluctant to use it.
