Highlighted
Awful download speeds
We have been with EE for the best part of a year and generally recieved speeds around 35-40Mbps. The last few days these have dropped significantly and are now less than 5Mbps, I've tried restarting the smarthub. The downstream is apparently 39.99Mbps but no amount of speed tests on iPhones, iPads, Xboxes and PC's gives a result even close to the previous. The tests on the Xbox and PC have both been via ethernet too. Any suggestions?
Highlighted
Re: Awful download speeds
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Highlighted
Product name:Smart Hub
Serial number:+EEH001+1806012240
Firmware version:v0.00.24.06190-EE
Firmware updated:Mon Jul 16 07:34:20 2018
Board version:01
DSL uptime:0 Days, 0 Hours, 35 Mins, 16 Secs
Data rate:9.99 Mbps / 39.99 Mbps
Maximum data rate:12.15 Mbps / 58.43 Mbps
Noise margin (up/down):6.4 / 15.1
Line attenuation (up/down):29.6 / 21.7
Signal attenuation (up/down):29.5 / 20.0
Data sent / received:102.9 MB / 175.4 MB
Broadband username:PRODUCTIONHQNUN349190517@fs
2.4 GHz wireless network name:EE-Hub-u6Fo
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:EE-Hub-u6Fo
5 GHz wireless channel:Smart (Channel 48)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:94:6A:B0:3E:CE:E7
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017)
Wired speed test
BT Availability Checker
