by IBP Contributor
Anyone else getting throttled to 3Mbps instead of 35Mbps?
I appear to be getting throttled, usually overnight, to around 3Mbps.
If I reset my router I get my full 35Mbps throughput for a while, then it goes back down, when I check the following day.
If I use Speedtest.net it says I have 35Mbps but an actual file transfer says otherwise, until I do a hard reset on the router that is. Could there be a proxy bypass for Speedtest.net? Can't be a router fault as it would not work for this website.
It's not like I download much, it's mainly used for gaming or streaming TV services. I notice when playing online that it's slow, again until I reset the router.
Anyone else get this?
7 REPLIES 7
Re: Anyone else getting throttled to 3Mbps instead of 35Mbps?
BB issues are almost invariably down to your own line, not anybody else's.
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
Hi @IBP
We'll do our best to help.
Please take a look at @XRaySpeX post above and get back to us with the numbers.
Thank you. 🙂
by IBP Contributor
Hello,
Thanks for getting back.
The router has been reset today, but I'll post these anyway and I'll do the same again tomorrow when the throughput drops.
1.
DSL Status
This page shows information about your DSL connection. If you are using Ethernet Broadband then this page is not applicable.
Status
Configured
Current
Line Status
UP
Link Type
Fast Path
Operation Mode
Automatic
G.993.2 (VDSL2)
Data Rate Information
Upstream
9345 (Kbps)
Downstream
40000 (Kbps)
Defect/Failure Indication
Operation Data
Upstream
Downstream
Noise Margin
6.3 (dB)
6.9 (dB)
Line Attenuation
0.0 (dB)
22.9 (dB)
Indicator Name
Near End Indicator
Far End Indicator
Output Power
5.6 (dBm)
12.5 (dBm)
Fast Path FEC Correction
6248
0
Interleaved Path FEC Correction
Fast Path CRC Error
0
0
Interleaved Path CRC Error
Loss of Signal Defect
0
0
Fast Path HEC Error STR
0
0
Interleaved Path HEC Error
Error Seconds
0
0
Statistics
Received Data
5187735 (Kbits)
Transmitted Data
823657 (Kbits)
System Uptime is: 01:48:26
2. https://www.thinkbroadband.com/speedtest/1522258034831838955
3. Widnes Exchange
Yes, thanks, please repost those results after a day or more w/out touching it. At the mo' your BB is fine.
by IBP Contributor
I'll check it tomorrow. It usually only lasts a day.
by IBP Contributor
Just thought I'd let you know that the broadband hasn't dropped in throughput since I reset it on Wednesday.
FIngers crossed!
Thanks! You're welcome :)! Glad I could be of assistance. Good luck that it holds.
