by t8769 Established Contributor
Activate WPS button on router
Many problems getting my printer to connect, was told by Cannon that this is a problem with some EE routers, and the WPS button has to be activated for it to work.
Anyone know how this is one of if it is a problem?
Hub about 14 months old.
Solution
Re: Activate WPS button on router
Sorry, I misidentified your router ☹️ . That's the BrightBox 2. The WPS button is on top centre. It is by default deactivated.
Login to your BB2 at http://192.168.1.1 as "admin" with the admin password on the label on the back of the router and navigate to Advanced / Wireless Settings / Wi-Fi Protected Setup & select Wi-Fi Protected Setup (WPS) : Enable . Then SAVE SETTINGS.
11 REPLIES 11
Which EE router do you have?
No model number I can see
Tried to upload photos but can't work out a way to do it, when I do the photo uploads, is on the site but then does not appear on the page.
You've done it successfully -) . They were just awaiting approval. I've now done so.
That's the EE Smart Hub. The WPS button is on L. It is already activated.
What does this mean? On the Left?
There is only one button, it is in the middle.
According to Canon, they have had problems with EE hubs not having activated buttons, are you sure about this?
Hi @t8769
Welcome to the community.
That's the Brightbox 2 router, the WPS button is in the middle. Is the button not working?
Check out this help page on connecting through WPS.
Solution
OK
How do I activate it.
Very strange that EE have sent it out like this.
I've already told you in https://community.ee.co.uk/t5/Broadband-home-phone/Activate-WPS-button-on-router/m-p/828831/highligh... .
Hi @t8769.
Have you been able to follow @XRaySpeX's advice and log into your router's admin page?
Jon
Yes
Thanks for the advice
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
