by Libstar1990
5GB Data Boost on 2 numbers
I've got two phone contracts under the same account, one of the numbers is my mums and she has the 5GB data boost for having home broadband.
But if I were to get home broadband for my place, would I be able to get the 5GB data boost on my number as well.
So basically is it possible to have 2 mobile numbers under the same account and both numbers get a 5GB data boost for having 2 lots of home broadband at different properties??
Solution
Re: 5GB Data Boost on 2 numbers
Yes, if you have 2 BB installations you can have 2 data boosts on diff mobile nos. When you apply for BB it will ask you what mobile no you want the boost on.
Solution
Welcome to the community, @Libstar1990 🙂
I think if the name and address matches, you should be able to get the additional data boost.
May be worth a quick call to customer services just to double check your account.
