by JohnOfedup Investigator
5-10 second delay on uploads, EE wash their hands.
So. I live in the sticks so grudgingly accept that my broadband is going to be slow. 3.5m down and about 0.75m up typical once wifi taken into account.
My service has seemed patchy of late and lagging when using a remote desktop, and a speed test shows a 5-10 second delay (consistently) on uploads.
So question 1, is would this account for the inconsistent service, question 2 is what can I do given the massively unhelpful operator at ee bluntly said anything to do with upload they can't help. At all. Great.
Screenshot below of test.
8 REPLIES 8
Re: 5-10 second delay on uploads, EE wash their hands.
So I have no idea if this is working, I'm just seeing a triangle so I assume not. This is going great.
You must be on ADSL2+ BB. You'll get about 1.3 Meg upload sync speed at most on that technology.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Your images need to be approved before they are shown. I have now done so.
So the router data :
Sorry for the poor quality, trying
to do this in a hurry with two devices. Uptime is 2hr03, I rebooted the router earlier because that's the first thing you try right?
Exchange is Chudleigh, Devon.
I can't do a wired speedtest, because I no longer own a device with an ethernet port. The point is, the speed is fine and what I expect when it actually happens, its the delay I was wondering about.
Original speed test:
https://www.speedtest.net/my-result/a/5379371134
New one using the link you provided, still wifi but comparable:
https://www.thinkbroadband.com/speedtest/1570719763447989155
So this test doesn't seem to have the delay. So is the issue with the ookla test and not my broadband?
If so, why is my broadband so patchy when the download speed routinely runs at what I'm expecting?
And frankly, why couldn't the operator on the phone be as helpful instead of just giving the big brush off?
You do have a lotta FEC Corrections for 2 hours. which may be slowing it down with retransmissions.
Can you change the DSL Mode to G.992.5 (ADSL2+) & repost the router stats?
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
DSL mode changed ☑️
BT Quiet Line Test ☑️
Done using hidden master socket on wired phone. There was a tiny bit of earth hum (you know, like you sometimes get on a flaky mic lead) but I it had to listen for it. No other noise or interference.
Screen grab below is rebooted router, plugged directly into master, after 3hr12 runtime.
Meanwhile, no discernable difference from the user's perspective...
I should keep on ADSL2+. It's faster for you.
Is that the test socket or the front socket of the master?
Test socket behind the cover
