by Bpk123
2.4 band dropping with 2 ssids
Hello,
New hear and might be a simple answer.
But I have just set a second ssid recently on my bright box 2 and while all worked well when I first did it, I now have an issue where the 2.4 band is discoverable but will not connect on any device unless I restart the router the 5ghz band is fine on all devices.
Some info about the setup for both
Modes available are b-g-n
Channel auto
Extension channel below
Bandwidth 20/40MHZ
Cipher suite auto
Vlan binding default vlan 2 for 2ssid
Any help is appreciated 🙂 and thanks in advance
Re: 2.4 band dropping with 2 ssids
Is that a 2nd pair of SSIDs or just a 2nd on the 2.4 GHz band?
by Bpk123
Its a second pair so 2.4 and 5 but the 5 os fine
