by wififred
wifi calling on samsung j5 prime
Hi. I have problem with my new phone samsung galaxy j5 prime i don't find wifi calling option on that could you let me know how can i built in this future
Re: wifi calling on samsung j5 prime
@wififred  Unless it’s changed and I don’t think it has WiFi calling is not compatible on that device.
Perhaps @Richard_C. can correct me if I’m wrong.
by Brilliant Contributor
Where did you purchase the phone?
Dial *#1234# and share the info please.
What do you see inside the settings if you go to.
Phone app > 3 dots right top corner > settings. Scroll to the bottom. Wi-Fi calling options on Samsung's are there normally.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Hi @wififred
Welcome to the community. 🙂
WiFi calling is only available on the Samsung J5 when purchased directly from EE. (@Chris_B, FYI). 🙂
Could you let us know where you got your phone from, @wififred?
That will help us help you.
Chris 🙂
