Highlighted
by Investigator
we are having serious issues with our Fibre Broadband. Download speeds are awfu
Download Mbps 1.98
Upload Mbps 3.51
Ping 33.50
These are the speed when using wired internet. I downloaded the Christmas episode of Victoria to my ipad this morning (wireless)and it took an hour. Someone help please. I have followed all of the steps as per the broadband checker tool. one thing that i have noticed, the adaptor that was in the box says ASDL, does this make a difference with fibre broadband?
9 REPLIES 9
Highlighted
Re: we are having serious issues with our Fibre Broadband. Download speeds are a
You mean the dangly filter? They are for both ADSL & VDSL.
If you would like help with your speed or connection issues, please would you carry out the steps and provide the data as requested in the Need Help with Your Home Broadband Speed or Connection? sticky. This will enable us to diagnose the problem and advise you further.
Highlighted
by Investigator
Highlighted
Hi @mummybraes
Thanks for coming here 🙂
Thank you for posting the stats for @XRaySpeX
 I'm sure he will try and help when he's next around.
Cheers
Richard
Highlighted
I am around but can't see anything :(.
Highlighted
Hopefully you will be able to see the image soon
@XRaySpeX
Thank you
Richard
Highlighted
by Investigator
How are we doing with an update?
Highlighted
It's nearly 24 hours & I still can't see it. It's not good :(.
Highlighted
EE Employee
Hi @mummybraes and @XRaySpeX
I have informed the mods there is still image unmoderated 🙂
Many thanks,
Lee
Highlighted
Have you recently had a fault fixed on your line?
The DLM system has put you on a banded profile in response to past errors on your line, at the top of the up to 2 Meg band of these VDSL Banded Profiles, altho' you now have no significant errors. You need to give the DLM time to relent & remove any banding. If your sync speed at the test socket remains stuck at the same speed for 10 days you should ask EE to investigate the underlying fault. If a fault is found and fixed then the OR engineer may request a DLM reset. However should significant errors persist the DLM will reapply banding.
