by stevie-999 Investigator
twitter app
on twitter i can access  on wi-fi but no updates on 4G any ideas, just changed my sim if that could be a clue
6 REPLIES 6
Re: twitter app
Check that you have twitter on sync under settings and that data is active.
Re: twitter app
High when you say sync do you mean make sure twittermobile date switched on
EE Employee
Re: twitter app
Hi and welcome to the community @stevie-999
Please do check that App data is indeed turned on.
Do you have any issues with any other apps?
Many thanks,
Lee
Re: twitter app
no non, just twitter when on 4G, worked fine when I was on T mobile I changed to EE on friday and not worked since
by Profile closed
Not applicable
Re: twitter app
You may need to remove content lock from your new EE account (the adult filter) which will always be on by default, details here.
Re: twitter app
Hi @stevie-999,
That's great advice from @Profile closed
Please let us know if that fixed the issue.
Thanks Smiley Happy
