by auldbob Investigator
transferring data
I have old Sony Xperia SP and would like to transfer contacts from my phone to my sim or sd card Thank you
by Ace Contributor
Solution
Re: transferring data
Hello @auldbob tap contacts>more>manage contacts>back up to save to an SD card or SIM card.
Thank you, for the reply, when I tap contacts all it does is bring up a list of all the contacts I have tapped various symbols within the contact list but to no avail
Regards, auldbob
by Ace Contributor
Solution
by Ace Contributor
You need to open up the settings menu in the contacts app. You can do this by clicking the three little dots at the top like all your other apps.
Brilliant! Have done it, great
Best wishes, ps don’t leave the country!
by Ace Contributor
I am glad to hear you have now transferred your contacts successfully.
The community is here anytime if there is anything else you would like to know.
