Highlighted
some apps not working on laptop (EE data sim)
I have EE data sim 32g plan for my lenovo laptop.
Some apps does not work due to ports being blocked, simple example: Spotify (but this is just one of them).
Anybody experiencing the same? Found a way to by pass this? Is there any proxy I need to configure?
Regards,
tex
Highlighted
Re: some apps not working on laptop (EE data sim)
Hi @texwi
Welcome to the community and thank you for posting 🙂
This may be worth checking your Firewall and Anti-virus settings to see if this is having an impact.
I would check to see if there are any blocks on specific ports and allow access that way if you can.
Let me know how you get on.
Richard
Highlighted
Hi Richard_C
Thank you for reply.
It's not an issue with antivirus software as all apps work when connected to WiFi.
I work in IT. I'm pretty sure on my end everything was done.
There is also a bit problem in obtaining full connection (getting ip address). My Lenovo mobile connect blinks all the time on getting ip address and never stops but connection is extablished asap regardless this.
I was wondering if there is any set up I need to configure on my end when using data sim or it should work just as poping it up into laptop and get connected?
Does EE block any ports for sim data users?
Regards,
texwi
Highlighted
Good morning @texwi
Thank you for coming back to me 🙂
I would advise to have a chat with our Technical team if you have time.
When you select the EE drop down, there is an option for an online chat with an advisor as well.
Please let us know how you get on.
Thank you
Richard
Highlighted
Yes, Port 25 SMTP, but that won't be affecting you.
