by matty88
New Member
sim question
ive lost my phone that was on pay as you go... can i get a replacement sim with the same number to use???
Solution
Re: sim question
Yes, either go into an EE shop & they'll transfer number & credit if applicable to a replacement SIM of correct size for free or order a replacement SIM for £1.50 by calling EE. You should report the loss of your phone to EE ASAP so they can block it.
by Ace Contributor
Re: sim question
The customer services team should be able to replace the SIM card for you. As long as you can answer all the security details.
You can also reach the team by phoning 07953 966 250 from a different phone.
W
Solution
Re: sim question
