Highlighted
by Investigator
"Error" in Mobile Hotspot Android Nougat
I can't seem to enable USB tethering or mobile hotspot when using mobile data on my EE 4G sim. I've tried rebooting, resetting network preferences and the like but nothing gives. I can enable the hotspot fine before turning on data but when I do, the hotspot has an error. If I do it the other way around the same thing happens.
7 REPLIES 7
Highlighted
Re: "Error" in Mobile Hotspot Android Nougat
Are you on EE, Tmobile or Orange?
Are you pay monthly or PAYG?
Have you tried deleting the system cache in recovery?
Highlighted
by Investigator
EE
Pay as you go
No, I'll try now, thanks
EDIT: It didn't work
Highlighted
EE Employee
Hi @maxiesnax
What device are you using?
Thanks - Karen. Smiley Happy
Highlighted
by Investigator
I'm using a rooted Nexus 5 running Android 7.1.1
Highlighted
EE Employee
Hi @maxiesnax
Do you know if the hotspot worked before rooting or was it not tested?
Many thanks,
Lee
Highlighted
by Investigator
It wasn't tested on this rom I'm using currently however it has worked peviously on other rooted roms. Could it be the rom?
Highlighted
EE Employee
Hi @maxiesnax
It does sound like an issue with the Rom.
Might be worth while popping over to XDA Developers as you may find the relevant information 😉
Cheers
Lee
