Highlighted
by Investigator
phone display issues
three days ago i placed my samsung galaxy j3 in my pocket and when i went to use it again it had a few coloured lines on the right side of the screen on the bottom so i turned off the phone and waited till i got home to resolve the issue however i forgot and the next day  i went to check the issue to look for online help but i noticed that from the left corner to the centre of the screen was completely black... i don't particulary want to replace the lcd as the make is verry expensive
7 REPLIES 7
Highlighted
by Investigator
samsung galaxy j3 screen issues
Highlighted
by Brilliant Contributor
Re: samsung galaxy j3 screen issues
@danpeterson Hi I would first try a factory reset if that doesn't work it should be under warranty
Highlighted
by Profile closed
Not applicable
Re: phone display issues
Hello @danpeterson can you remember if the phone was put under any strain or pressure when in your pocket? If there are lines across the screen and it is blobbing black or parts of it are failing then it is most likely permanently damaged and would need replacing. 🙂
Highlighted
Hi @danpeterson
Thanks for coming to community 🙂
I'm sorry to read about your phone, it's awful when a headache like this comes up.
Has the factory reset @Damienw1 suggested helped things?
If not, it may be worth popping into your local Samsung support center and they may be able to help you out.
Either way please let us know how you get on.
Thank you
Richard
Highlighted
by Investigator
i left the phone for a day and now the blackness has consumed the whole screen i dont think the phone was put under stress but there  were green lines, will charging the phone reduce the blackness at all
Highlighted
@danpeterson You can only try although I fear this is a faulty handset but if you didn't damage it it should be under warranty
Highlighted
Hi @danpeterson
Please see my reply to you also here and I hope you manage to sort everything out.
Let the community know if there is anything we can do further to support you.
Cheers
Richard
