Highlighted
no double speed plan for home 4Gee Router...
Hi There,
I just got my new router on the 200GB plan.
I'm disappointed that double speed is only offered to mobile plans, not home routers...would EE consider changing this policy?
Matt
Highlighted
Re: no double speed plan for home 4Gee Router...
Hi @firematt
On the features page/tab it says:
As fast as fibre
Our top 4GEE speeds are as fast as standard broadband. You could go up to 90Mb/s – that’s faster than most people’s average Fibre Broadband speed. You can also connect a whopping 32 devices at once
So I assume it does cover those speeds as the device is capable subject to the area you live/use the device.
Thanks,
Highlighted
EE Employee
Hi @firematt and welcome to the community.
Hope the above information has helped.
Many thanks,
Lee
Highlighted
by Ace Contributor
The 4G home broadband router they sell is capable of 300mbps, certainly performance over the 90mbps stated is not uncommon.
