Highlighted
by Investigator
my texts are being sent twice
my text messages are being sent twice, i have done a system cache clear and they are still sending twice
11 REPLIES 11
Highlighted
EE Employee
Re: my texts are being sent twice
Hi @melody2017 and welcome to the community.
Are the texts, sending twice to everyone?
Many thanks,
Lee
Highlighted
by Investigator
Hi yes it sends them twice to everyone! Most bizarre.
Highlighted
EE Employee
Hi @melody2017
Could I get you to delete one of the conversations, and have the other person do the same thing.
Let me know if this corrects the issue.
Many thanks,
Lee
Highlighted
by Investigator
Hi it has rectified it for the indidvidual, will i have to do it with everyone though?
Melody
Highlighted
EE Employee
Hi @melody2017
It does sound like that, I know it's not ideal, but least it is resolving your issue.
Many thanks,
Lee
Highlighted
by Investigator
Thanks for your help much appreciated 🙂
Highlighted
EE Employee
Highlighted
by Ace Contributor
I can't say I've had this issue, so not sure what to suggest, but if it was me, I'd back up my texts using an app like SMS Backup and Restore (I use this weekly and upload to google drive), then you should be able to delete them all from your phone, and restore them from the backup. May be worth a try before just deleting them all?
Are you using just the stock messaging app from your phone? Maybe try a different one too, I use ChompSMS
Highlighted
EE Employee
Highlighted
by Investigator
Thanks i will give it a whirl 🙂
Highlighted
EE Employee
Let us know how you get on 🙂
Cheers
Lee
