Highlighted
by Investigator
my 4 didit number is not unlocking my phone what other ways can i use my phone
my 4 digit pin number is not unlocking my phone how can i resolve this thanks
9 REPLIES 9
Highlighted
Re: my 4 didit number is not unlocking my phone what other ways can i use my pho
Highlighted
Hello there @no1tomo
Thanks for posting on the community.
As @Chris_B has asked what phone are you using?
Has this code worked previously for you?
Speak soon 🙂
Highlighted
by Investigator
sorry forgot to say its a samsung s6 curve and yes been useing the same 4 digits for a couple of months now
Highlighted
Thanks @no1tomo
Does the phone say this is incorrect?
Thanks, Leanne.
Highlighted
by Investigator
yes it says its incorrect and driving me nuts
Highlighted
Hi @no1tomo
Thanks for replying 🙂
It may be now a case of you needing to reset the password.
Is their a forgot password link on the home screen?
Thank you
Richard
Highlighted
by Investigator
just my luck there aint nothing along thjose lines thanks
Highlighted
Try not to worry @no1tomo
I'm going to ask for some help with this from @Chris_B @Northerner and @BrendonH
When they are available I'm sure they will try and help.
I know we have a couple of android users there who may just be able to help you.
Cheers
Richard
Highlighted
by Brilliant Contributor
If your pin isn't working then the only way to get in is a factory reset.
There is no forgot pin etc.
Are you sure you haven't accidently changed it? Or anyone else knew your pin and changed it? As this doesn' just stop working.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
