Highlighted
by Investigator
mobile data problems
Ever since i have upgraded the android software i have intermittent mobile data, i have reset the phone no joy, reset the APN sometimes it works (Rarley) any help please
im on a personal account samsung s7
Highlighted
Solution
Re: mobile data problems
Does this only happen in one location for example at home?
Have you checked your local mast for issues here.
If you have factory reset and this still doesn't fix the issue then have you and security software installed? If you go into settings - data/mobile data have you accidentally activated limit data?
If this fails then try reinstalling the firmware via Samsung PC software.
Highlighted
Solution
Highlighted
by Investigator
hi,
this happens every where since the firmware update, i have checked the link for mast issues and there is a problem, i will try again when they have solves the mast issue,
thankyou for your help
