by Zatchlas Investigator
iPhone can’t connect to Twitter or Facebook on data connection
Hi there,
I am unable to connect to Facebook or Twitter when on 4G, and just get the below screen. It won’t work on the apps either. When I use wifi, everything works absolutely fine. I have an iPhone 8 with iOS 11.1. What am I doing wrong?
Solution
Re: iPhone can’t connect to Twitter or Facebook on data connection
So I contacted EE support, who said I had to contact Apple. They told me to reset all settings, and hey presto - no more problem!
12 REPLIES 12
Hi @Zatchlas
Welcome to the community. 🙂
Just for speed (while the mods accept your screenshot), what does it say when you try to use it?
Hey thanks so much for replying!
It says:
This site can’t provide a secure connection
twitter.com sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
OK, thanks for getting back to me @Zatchlas.
Could you please try the following?:-
1. Delete the app and re-download
2. Reset the network settings - Tap Settings >>> General >>> Reset >>> Reset Network Settings >>> Follow prompts.
Please let me know if either of those steps help.
Hi there,
I tried both those things, but the same error persists.
Thanks for all your help, by the way!
No problem at all, @Zatchlas.
I don't think this is causing the issue, but, could you check to make sure that mobile data was switched of for both Facebook and Twitter:-
Settings >>> Mobile Data >>> Toggle each of them on.
Could you also make sure that your date and time are set correctly/set automatically?
Settings >>> General >>> Date & Time >>> Set automatically.
Chris 🙂
Hi Chris,
Checked all that, still no change. 😞
Thanks for trying, @Zatchlas.
I'm all out of ideas.
I recommend having a chat with our technical support team.
They will be able to run some more troubleshooting for you.
Please let me know what they say and how they fix it. 🙂
Solution
Hello @Zatchlas
Thanks for coming back and letting us know.
Come back anytime 🙂
by jimbo12
This works! Thank you
Glad you got the help you needed from the community @jimbo12
Come back anytime 🙂
