Highlighted
iPhone 5s unlocked ?
I've been through the unlocking procedure, but how do I verify that it is actually unlocked?
7 REPLIES 7
Highlighted
Re: iPhone 5s unlocked ?
@NightRail    If you’ve been told it’s now unlocked all you need to do is put a different network Sim card in the device O2 or Vodafone are the best SIM cards to use to process the unlock on the device.
Highlighted
EE Employee
Hi @NightRail and welcome to the community.
Do let us know how you get on after following the advice given by @Chris_B.
Many thanks,
Lee
Highlighted
Because i'm still using it on EE I had to do a full reset, as per instructions. My contract has 3 more months to run, I was just being prepared early. But I don,t know how to verify it is actually unlocked.
Highlighted
@NightRail  Put a different network SIM card in n the device.  You have to do this to complete the unlock process.  Use a o2 or voda SIM card as 3 SIM cards can sometimes not work when doing this.
Highlighted
EE Employee
Hi @NightRail
You can pick up another network SIM card from the £1 shop to give it a quick test.
Many thanks,
Lee
Highlighted
@Lee_H wrote:
Hi @NightRail
Many thanks,
Lee
Ok, thanks. I'll try that.
Highlighted
EE Employee
Hi @NightRail
Let me know how you get on.
Many thanks,
Lee
