Highlighted
does ee40VB-2ae8gb3 support band 40?
Hello,
I would like to unlock my ee40VB-2ae8gb3 so that I can use it in another country when I travel, instead of buying another modem for this purpose,
Currently, I have travelled to Iraq, and I have bought a 4G Sim Card, but it has the frequency of 40TDD (2300 MHz), My question is that, does my modem chipset support band 40?
I searched online, but it seems it doesn't support it, but I wonder if the chipset itself support it or not.
Highlighted
by Ace Contributor
Re: does ee40VB-2ae8gb3 support band 40?
Welcome to the community.
The device is intended for EE and UK frequency bands, as far as I can recall from the box label, LTE (1, 8), 3, 7, 20 with no TDD support.
Highlighted
Hi Peter,
Thank you for your answer on my post,
I doubt the chipset only support these bands mentioned on the box, or on the internet, I think the chipset might support more bands, do know the chipset model?
Thank you
Highlighted
by Ace Contributor
Even if the chipset does, the radio system within the device most likely won't.
Highlighted
Thanks for helping @danarjamal out @Peter_C
Cheers
Richard
