by curzon
data usage
Hi .. until recently live streaming a football match used to use approx 1gb of data,
now it is using approx 3gb , and yes i`m sure i`m choosing to watch in SD and not HD
what could have changed ????  Thanks
7 REPLIES 7
Re: data usage
This is an impossible question to answer without looking at your device and other usage.
Check under your data app (settings) to see what what accessing data at the time.
Thanks,
EE Employee
Re: data usage
Hi @curzon and welcome to the community.
Which app are you using to live stream the football?
Many thanks,
Lee
by curzon
Re: data usage
Hi Lee and thanks ... using both BT SPORT (free with EE ) and Sky go
as I said all was fine until recently
EE Employee
Re: data usage
Hi @curzon
I will run a text on data usage via the BT sports app and let you know my findings
What phone are you using?
Many thanks,
Lee
by curzon
Re: data usage
thanks Lee ... it a tablet ... samsung galaxy tab A 10.1
EE Employee
Re: data usage
Hi @curzon
I'm currently testing the BT app via 4G steaming the Moto GP.
I will do this for 90 minutes and then report back with my data usage 🙂
Many thanks,
Lee
EE Employee
Re: data usage
Hi @curzon
After testing for 90mins I used 1.17GB watching BT Sport App.
Hope this helps,
Lee
