Highlighted
by Investigator
Y854 Modem Does Not Fully Charged
Hye,
I owned y854 modem. After not using it for nearly three months, it has charging issue. Usually after charged the modem for 4-5 hours, it will fully charged. But now, even after 10 hours charging, the modem only charged only at two bar full out of four. Now it's  battery only last 9.5 hours. Can it be fix?
Highlighted
by Profile closed
Not applicable
Re: Y854 Modem Does Not Fully Charged
Hello @ahmadharith do you have a different charger you can try? This will confirm if the actual device is faulty or not. 🙂
Highlighted
by Investigator
Yes, i have try charged it using two different cables and power adapters, but still not fully charged.
Highlighted
by Profile closed
Not applicable
Hello @ahmadharith you likely have a faulty device then. Does it still not charge properly after a full reset by sticking a pin or bent paper clip in the little reset hole underneath? If not you would need to look at either getting it replaced or repaired/exchanged through the warranty if it is still valid. 🙂
Highlighted
by Investigator
Already reset it too but still not works. No warranty anymore 😞
Highlighted
by Profile closed
Not applicable
Sorry @ahmadharith looks like it may be time for a new device then I am afraid.
If you keep any future ones in storage for prolonged periods of time again running the battery down and charging it back up to about halfway every now and again should help to make them last. 🙂
