by IntradayTrader Contributor
Would a directional high-gain external antenna give me more consistent 4G+?
I was playing with my Netgear Nighthawk M1 today and the best internal signal I can obtain is a full 5 bars 4G (RSRP -64dBm/RSRQ -6dBm). Occasionally, the 4G+ network is connected, which I'm about 100m outside of according to the EE coverage checker. I'm quite happy with the up/down 100/40Mbps speed, but the faster the better, right? Would fitting a good quality directional high-gain external antenna give me a more consistent 4G+ connection?
6 REPLIES 6
Re: Would a directional high-gain external antenna give me more consistent 4G+?
Hi @IntradayTrader
I'm delighted to see the speeds that you're getting and that you're happy with them. 🙂
This is a bit above my level of expertise, I'm afraid.
@Peter_C or @XRaySpeX may be able to advise on this? 🙂
by Ace Contributor
Yes, a directional, high gain external antenna will provide a far more consistent 4G+ signal experience.
The Nighthawk M1 uses two TS-9 antenna connectors, whereas most antennas use SMA so adaptors will be required.
Solwise is a retailer that sells what is required:
SMA to TS-9 adaptors 2x ADAP-TS9-SMASKT here
Top end antennas: 2xNET-3G-LPDA-0092 here
Thanks @Peter_C 🙂
Thanks for your reply @Peter_C.
I have one of these arriving tomorrow, which will be useful for when I'm travelling. I'll test whether or not I can get a good external 4G+ signal with that before deciding to go with one of your suggestions, or the Poynting and Panorama Antennas alternatives I've seen.
by EamonnC Contributor
The M1 has 4 internal aerials to get speed you require. Using the 2 ports to connect to an external aerial may improve connection but reduce speed.
by Ace Contributor
The vast majority of sites are 2T2R and therefore the additional antennas will only help by virtue of receive diversity. The gain from external antennas should very substantially outweigh this.
