by GailN80
Re: Wireless PBC connection to printer - "Error Detected - Please try agai
Hi James,
Sorry for delay in responding, yes I have gone into advance settings and made sure WPS was enabled.
Gail
Sent from my iPhone
EE Employee
Good Morning @GailN80
Are you able to try connecting something else to your router vis WPS?
Just so we can try and rule out what is causing the issue.
Thanks - Karen. Smiley Happy
by GailN80
I can disconnect my laptop and see if it finds it again if that helps? How many device can a bright box 2 handle? Mine has 3 x Xbox 2x desktops 1x laptop 3 x tablets 4 x phones 1 x tv and a WD box?.
Thanks Gail
Sent from my iPhone
Laptops don't connect to WiFi by WPS.
EE Employee
Hi @GailN80
I don't believe there's a limit - that shouldn't be causing the issue.
It might be worth trying to set it up using a wired USB connection.
There's some FAQ's on the Epson website.
Let me know how it goes!
by GailN80
Thank you 😊
Sent from my iPhone
EE Employee
No bother.
I'll keep my fingers crossed that everything gets sorted.
by w1lson17
New Member
Hi
did this issue get resolved?
im having the same issue can’t connect my printer.
im clicking start pbc and getting an error detected message.
bruce
