Highlighted
Will ee stock the ice platinum LG G6?
Simple question. Will ee stock the ice platinum LG G6? If so, when.
Thanks,
Highlighted
Solution
Re: Will ee stock the ice platinum LG G6?
At this time no but keep an eye out in the shop area as they may do in the future.
The black one is great BTW as the screen blends into the bezel.
Highlighted
Solution
Highlighted
Thanks for responding.
Do you know why not?
My phone is broken and I need a new one asap. I want the ice platinum G6, and I see carphone warhouse and other providers do have the ice platinum phone.
If I get the black edition, just to have a phone, would EE swap the phone if they do start to stock the ice platinum colour?
Thanks,
Highlighted
At the moment EE  only stock the black version. If they did decide to stock another colour then you wouldn't be able to exchange.
You can upgrade your EE contract via a third party such as Carphone warehouse as they stock all three colours. The only fit freebie is the CPW versions dont come with EE firmware.
