by Jambo2
Will a samsung note5 unlocked work on EE
Solution
Re: Will a samsung note5 unlocked work on EE
@Profile closed: True. I was really answering in the context of the Q. I should have qualified it by "compatible".
by Jambo2
Samsung note 5
Will an unlocked note5 work on EE
@Jambo2: Any unlocked device will work on EE.
by Profile closed
Not applicable
Not necessarily, especially if the handset is an import.  The Galaxy Note 5 was never released in the U.K. so this handset will be an import.
Looking at the specs though, it looks like all versions should be OK and should work here as they all do have band 1 (2100Mhz) for 3G and band 3 (1800Mhz) for 4G.
A couple of versions don’t look look to have band 20 (800Mhz) for 4G so whilst it will work on EE in most places, it’s not going to work with O2 or Vodafone.
Solution
