by Tylerd
Will BT sim work in phone locked to ee?
Hello, if  I buy a used iphone locked to EE will I be able to use my BT SIM in it? I have been told by BT that the answer is no but have read several times online that this is not correct as BT uses the ee network.  Thanks
by Profile closed
Not applicable
Solution
Re: Will BT sim work in phone locked to ee?
Hello @Tylerd yes an iPhone locked to the EE network will accept a BT SIM card. 🙂
13 REPLIES 13
by Profile closed
Not applicable
Solution
by Tylerd
Thanks very much for the  quick reply. Sorry if this sounds cheeky, it's not meant to, but are you able to confirm that this is definitely correct. The reason I ask is that when the BT chat line told me yesterday that a BT sim would NOT work in a phone locked to ee I asked the girl to double check and a couple of minutes later  she came back to me and confirmed that it definitely would not work. I am trying to buy a used iphone and the ones which are locked to ee are a fair bit cheaper than the unlocked ones but I don't want to go ahead unless I can be sure that I won't have to go through the unlocking procedure. Thanks again
by Profile closed
Not applicable
Hello @Tylerd which model iPhone are you thinking of purchasing? 99.99% of the time an iPhone 4 or above locked to EE will accept a BT SIM card. An Orange locked iPhone 3GS or below may not but a T-Mobile locked iPhone 3GS and below should. All EE devices should accept an EE/T-Mobile/Orange & their MVNOs (Virgin/BT/Asda etc) SIM card. 🙂
by Tylerd
Tom222, it's the iphone 6s plus
by Profile closed
Not applicable
Hello @Tylerd yes an iPhone 6S+ locked to the EE network will accept a BT SIM card. 🙂
by Tylerd
Brilliant! Thanks very much for your help Smiley Very Happy
by Profile closed
Not applicable
You are welcome @Tylerd come back to the community anytime if there is anything else you would like to know. 🙂
@Tylerd: Here is 1 of the EE staff confirming the fact: https://community.ee.co.uk/t5/Android/just-joined-EE-need-to-use-new-sim-are-contacts-secure-when-I/... .
by Tylerd
Will do Smiley Happy
by Tylerd
Really sorry Tom222, I wongly thought the  post from XraySpex was from you and clicked on the Solution button.I don't seem to be able now to do that for your reply but I have given you a star. Apologies again.
by Tylerd
Thank you, XrayspeX
You're welcome :)! Glad I could be of assistance.
by Profile closed
Not applicable
No problem @Tylerd I have marked the original post as intended for you. If it happens again in the future just tap the small cog icon at the bottom right of the post and select 'Not the Solution' to remove it. The option to choose whichever post you want should then reappear. 🙂
