by DavidByrne Investigator
WiFi unit on EE
I had iPad stolen.
Put replacement sim into EE mini WiFi unit.
On device it shows a visible connection but won’t allow access to internet.
Many help appreciated.
David
6 REPLIES 6
Re: WiFi unit on EE
What does it tell about your data when you browse to http://add-on.ee.co.uk/status ?
Re: WiFi unit on EE
Re: WiFi unit on EE
Hi and welcome to the community @DavidByrne. 🙂
Could you please try resetting the device?
  1. Remove the bumper to uncover the Reset button.
  2. Using a paperclip or pen, press and hold the Reset button for approxamately 5 seconds.
  3. The device will restart automatically.
Re: WiFi unit on EE
You have no data allowance. Maybe it wasn't transferred.
Re: WiFi unit on EE
Thanks for all your help. Just found out that the line was still under suspension after reporting theft. All working fine now😎😎😎😎
Re: WiFi unit on EE
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
