by Nvm91
Why is roaming in Spain not working
Why is roaming in Spain not workin , I am unable to send texts
Re: Why is roaming in Spain not working
Hi @Nvm91
Did you activate roaming before leaving the UK?
Are you on PAYG or an EE pay monthly customer?
EE Employee
Hi @Nvm91 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
