Highlighted
Why don't my Samsung handset and EE data usage figures match?
I have a Samsung Galaxy S7 Edge and for the past three months my handset is reporting mobile data usage at a level roughly three times greater than that reported on my account by EE. For example, this month so far, EE says I have used around 2.5 GB of data but my phone is suggesting I've used almost 8GB of data. In the previous months, I used around 5 - 6 GB according to my phone, but only 1.5 - 2GB according to EE.
Why would this occur?
Many thanks.
7 REPLIES 7
Highlighted
Re: Why don't my Samsung handset and EE data usage figures match?
For clarity, the figures provided by my phone are for Mobile data only.
Wifi data is recorded separately and is much greater.
Highlighted
Hi @emmamcnab,
Welcome to the EE Community.
Have you set your data counter to start on the same date your data refreshes?
Highlighted
Hi James,
In answer to your question: yes. My data counter covers same period as my bill, i.e. 2nd of the month to 1st of the month.
Sent from my Samsung Galaxy smartphone.
Highlighted
Hi @emmamcnab,
I've got to admit, this one has me stumped!
I haven't seen any other cases with such a big difference in reported data.
@Northerner - are you using an S7? Have you come across this issue before?
Highlighted
I have checked mine and it's about a few MB out only so nearly about right.
The EE app counter isn't real time so try closing it down and restarting.
Highlighted
by Established Contributor
@emmamcnab
i found using the wifi hotspot sometimes it incorrectly dubbles up the data useage (using a VPN or TOR seems to allways do it for me the past)
Highlighted
Thanks for checking @Northerner
@ukperson - Thanks sharing that, I haven't noticed that happening before.
Maybe @emmamcnab can confirm if she has been using her phone as a hotspot.
