Highlighted
Why does J3 not connect to Virgin wifi
My Galaxy J3 no longer connects to my home Virgin wifi hub. No problem with other wifi services (eg at work or in coffee shops etc).
I have trawled forums - seems to be a common problem - with no success so thought I would come to EE community  (phone supplied by EE).
Any suggestions?
Highlighted
Re: Why does J3 not connect to Virgin wifi
@rd2000: Get up the Virgin Hub's SSID on your phone & tell it to Forget it. Then select it again & type in its pwd. It should now connect.
Highlighted
Good morning @rd2000
Thanks for posting in community 🙂
I'm just checking to see if the fantastic piece of advice given to you by @XRaySpeX has helped get things working?
Cheers
Richard
Highlighted
Hi Richard
Thanks very much for suggestion but no joy. I'd already tried 'forget and reconnect' and 'battery out and restart' but nothing. I can't even get to point where I'm asked for password.
Get Outlook for Android
Highlighted
Hi @rd2000,
Is your router visible in the list of available WiFi connections on your phone?
